UPDATED: My slow build...new pics
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
heres a tip... use much better oil that stuff is nasty...
stay away from cleaners you stick in the engine and run it then change oil.
mainly because i dont see how kero can be good for rod bearings and seals and the like.. kero is way to thin to **** well. not to mention engine cleaners you run dont do crap anyways its best to tear down and clean manually that is if you have the time money and tools.
also what i did if you clean the intake... (learned this off area91) buy to filters for the intake vac lines one being a carb fuel filter for the vac line coming off the front valve cover and the other being a breather filter over the line that goes in the back of the throttle body (big bastard) on the end going to the throttle body plug it off with a hose and bolt or whatever...
this will help keep the intake clean a lot longer.. amazing how much sludge going back into the engine because of emission crap.
basicly the second filter i speak off will vent the crank case to atmosphere and when running you can see the gunk coming out of the filter that would normally go back into the intake and cause the gunk to build.
other tips many have spoke of already
angelsmaybleed
shogun[914]
accord, new york
well ive only done 1 oil chang on this car as of yet i puchased it in january and she sat for a lil while i used quakerstate high milage...right now im slowly cleaning all the carbon build ups i dont have a knock or tick from this engine at all and there is a new timming belt on it so im assuming that the timing and the valve shims were done because serious next to no noise at all but it seems like they decided not to do anything else when they did all that
angelsmaybleed
shogun[914]
accord, new york
ok so ive finished cleaning everything out so now i want to paint the manifold, valve covers, timing cover, throttle body, maf and a couple other small parts so ive been looking around the forum at past posts about the topic and ive gotten a good understanding of what to do...at least i think lol but if anyone has any tips on any special areas that are over looked when taping off everything Ex. "places where things ground too" or anytips on how to make it come out as good as the ones i've seen around here then please feel free to share...thanks guys...one more thing the "snakes" how do u assemble them after paint so that they dont rub and scratch the paint ive been trying to figure this out for days when ever i put them back to gether they rub alot
angelsmaybleed
shogun[914]
accord, new york
one more thing my car is a black/black 92 so i was going to paint everything black but i want some accent under the hood as well ...so i was going to go with the blue couplers, blue plug wires and the new blue vacume line set from sho source and anything else i could get in blue....think it would look good?
SASHO91
Zoom Zoom
San Antonio,TX
Bring the "extra" Yamaha stickers to the KC meet and I bet you'll get rid of all you want . . . .
I like mine better! :evilgrin:
100 0186
post ******* FTW... :nut:
Seriously though, if you go to a sticker place, more than likely they'll have some sort of "Yamaha" sticker/emblem on file.
That's how I got mine done... it's vinyl as well.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Search on ebay for Yamaha Motorcycle badges and stickers, that's where I found mine. I though I was getting 12 of them, and ended up getting about 40. They ship from Hong Kong, and many other people have gotten the extra 'gifts' with their orders as well.
angelsmaybleed
shogun[914]
accord, new york
you want some pics?
well i painted a bunch of crap so heres the pics
IMG 1198
IMG 1199
IMG 1200
IMG 1202
IMG 1203
IMG 1205
IMG 1206
is there any way to clean all this up withought disassmbling everthing?
IMG 1150
angelsmaybleed
shogun[914]
accord, new york
yeah im post ******* lol...ok during my research of past threads about under hood painting i got the impression that clear coating was a bad idea...duplicolor makes a high heat engine clear coat rated at 500 degrees anyone ever use it? if so how did it turn out
angelsmaybleed
shogun[914]
accord, new york
ok so im not getting my damn stimulus check until mid july so i cant put my intake back together until then so while its off and i have the time what are some mods that are worth while to do on it gasket matching,removing horns,bbb,porting...anything else? figure ill do it all in one shot instead of taking it apart all over again
johndallara
Chapel Hill, NC
SHO project in progress
painted parts look really good. that engine will be sharp when you get it back together.
now is certainly a reasonable time to do porting, BBB mod, etc. -- although its a shame you just painted the stuff, might need touchup when you are done.
I used clear coat on top of the intake and valve covers (the 500 degree stuff) and have not had any problem. just put it right on top of the sanded intake and painted valve covers.
JD:salute:
Cocoa,Florida
make sure to sand down the grounding points on the intake manifold.
at the crossover tube and the rear where the ground wire is located.
SHOOFF508
Out of Retirement (again)
Westport MA
Sticker from a guy on ebay. Look in the badges and stickers section in Asia motorcycles, them Yamaha. I bought 12, and got about 40. WAAAYYY to many, but lots of different choices. Only like $12!!!
would you be willing to drop a couple in an evelope for the cost of a stamp and help a brother out that would RULE dude !
