SHOWYA
TurboSHO Member
This happens often once the engine is warmed up. I will be at a stop and when trying to shift to first it will be really hard to do. I can force it in and it will not grind. Somtimes i will have to rev up the engine a bit, engage the clutch and then it i'll be able to shift into first. Also, if i force the gear in and let go of the brake the car will slowly begin to move forward even with the clutch all the way in.
I replaced the clutch about 2 yrs ago. I installed the SS HiRevs Race clutch which has about 3500lbs pressure plate. Clutch is very stiff but its not a problem for me, gotten used to it!
My point about the clutch is that being in my newbie stage when i replaced the clutch i did not replace or reground the flywheel. Is this my problem or am i looking for a tranny rebuilt already?
<small>[ November 21, 2003, 02:48 PM: Message edited by: SHOWYA ]</small>
