benjammin
So Ive been having problems with my car not idling properly and surging at steady throttle. The car throws a 332 code and says weak # 3 cylinder during the cylinder balance test. I unplugged the vac line from the EGR valve and plugged it and no difference in idle....so that should tell me thye sensor is working. Next I put a vac line on the EGR itself and sucked...the idle dropped, so that tells me the EGR valve itself is good. I cleaned the EGR port through the intake but symptoms remain. Would the next logical step be to focus on plugs and/or wires?...BTW, I already replaced the IAC and cleaned the MAF.
