Unsual 3.2 swap question well sorta
92sho16
b00sted
Liverpool, NY
I am starting on a new project putting a SHO motor into another vehicle. This vehicle is going to have manual steering and no a/c so I want to run one belt. Naturally 3.2 accessories came to mind. I've searched and most things that came up when i searched was 3.2 swaps and people ditch the 3.2 acc for 3.0, I basically want to do the reverse i have a 3.0 block and want 3.2 accessories. So my question is do i need the 3.2 cast accessory brackets to run the the tensioner and alternator? I know the water pumps are the same and that just the pulley is different so get a pulley and I am set there.
Shoaz
Studly dood
Scottsdale, AZ
Yes, the cast iron accessory brackets and accessories from a 3.2 are most of what you need. I think there may be a mount point on one head that you may need to tap.
This does not match my experience - when I put a 3.2 w/ mtx accessories, we had to swap the water pump to get the pulleys to line up.
92sho16
b00sted
Liverpool, NY
All good information, thank you everyone. I might just have to stick with the 3.0L accessories at first, just put a brand new water pump on this motor.
32MTX
North Palm Beach
I can tell u with 100% certainty the water pumps are different between a 3.0 and 3.2
the pulleys won't line up casuing you to blow belts, and its missing a hole for the tensioner bolt to go through, so I think you can't use the upper left tensioner bolt with a 3.2 water pump.....
lowc
aka vapah lock
Quincy, massachusettes
and the lower coolant pipe off the pumps are different and with the 3.0 timming covers these is a gap in the back of it u can see the 30 tb tntioner through it
93rev2sev
Hockeytown
You'll want the 3.2 front mount, too...or at least the top half...and the bracket for the AC needs to be from a 3.2 also, I think.
92sho16
b00sted
Liverpool, NY
So since most of your questions have been answered...
I'll ask: What vehicle is the motor going into!!??
I plan on posting a thread soon, i just went to pick up the vehicle two weeks ago. I wanted to get some substanstial progress first. I'll give you a hint though its going to be about 800 lbs lighter than a taurus with two less seats or three less i guess really.
92sho16
b00sted
Liverpool, NY
Yea i was thinking about finding some brackets and cutting them up to use what was necessary but that was when i thought the water pumps were the same. I guess that might end up being an evolution of the vehicle but for now ill get it running on the 3.0L acc.
