Turbo SHO ISN'T BLOWN, NOW ITS FIXED!!!
1995SHO9
FLEES ARE COMIN
Carlisle PA
K onda con este thread, varios hombres diceiendo k se aman?!?!?!?!?!?!?! eso me parece un poco homosexual. Y k onda con la gramatica? El amigo del OP es un HDSPM, y no sabe nada! Mi SHO no sirbe y estoy DURO!!!!!!!!!!!!
Good work on using a translator, not really. :
dios maldito, perro del martillo.
escúchame. necesitas tener respeto por mi amigo. debe bofetada en la cara. mi amigo sabe más de ud y lo que respecto. Y gracias por decirme que tú SHO funciona. No es la verdad. Tú espanol es muy malo.
expy916
sacramento
Primero, yo no le estaba faltando el respeto a tu amigo. Segundo, no me andes diciendo que mi español es malo tú tienes el español malo. Tú usaste la palabra tú en vez de tu. Tú digiste "you spanish is bad". Además, tú digiste que yo debo bofetada. ¿Y cómo tu amigo va saber mas que yo de lo que pertenese a mi? Y mi SHO NO sirbe!
SHO GoDz 89
True Sleeper
Monroe Twp, NJ
What did you say about my mother?! :finger:
1995SHO9
FLEES ARE COMIN
Carlisle PA
don't you mean filter?
No, I mean the fuel pump was totally clogged.
Why was there dirt in your tank? I'd think about dropping the tank assembly and taking it to a radiator shop to have them clean that entire tank out.
The filter on the bottom of the fuel pump had fallen off. The metal screen on the fuel pump was totally cloged with dirt.
hawkeye18
Sorta cares
Norfolk, VA
hmm... yeah... dirt in the fuel tank is something that would generally concern me. But, you might as well replace it with a fuel cell while you're in there... :biggrin:
Jonny Cash
Good boy
Hollywood, FL
He probably has a rusty tank. Its happened to me. Take the pump out and see if theres buildup on the screen.
AREA 91
PA SHO SHOP
Area 91
Hey John, remember "Do it right the first time".:p
1995SHO9
FLEES ARE COMIN
Carlisle PA
:wave:
Anyways, we still on for this thursday at around 6pm? Pump is done, but I wanted to put a new o ring on it and seal it up alittle better. Also wanted to put on new rotors, calipers and pads in the rear and do a once over and make sure she is ready to be beat on.
sho_sc
Georgetown, KY
:wave:
Make sure you change the fuel filter too ....
AREA 91
PA SHO SHOP
Area 91
:wave:
Your on your own.
shop is closed.
