NJSHO said:
Your wheel doesn't hit that piping at full lock?
no, we have over an inch of clearance there, even more is possible too
antbrdwar said:
You forget the turbo is loud because its open dump right now
what alex was refering to is the fact that you can hear the compressor side of the turbo over the exhaust note.... sounds like a jet engine @ full boost
1slickRED89 said:
you should not need to pull timing with 93-94 octane gas, you'll lose that sweet tip-in throttle response!! awesome job getting it running!!!
we might have to have a Turbo ATX race, once yours is all worked out. maybe at the next convention.
throttle response is unimportant right now, making sure it makes it to the dyno is our main concern. throttle response still feels quite good tho. im very happy that we pulled timing ... see the "torn hose" section of todays events below
pudge235 said:
that set up looks great. You should think about selling it. It seems you guys have thought about everything.
weve thought of alot, there are a few things left top sort out b4 i would even consider doing a second car, and i DOUBT that i would ever build a kit, there are very tight clearances EVERYWHERE, previous frame damage or variations in tire sixe would easily make it impossible to install. plus it this setup requires modifications to the subframe
ok ... so heres the rundown on the first full day:
started off by setting the fuel pressure, took care of a small oil leak, swapped in the good plugs, checked for any visable problems, charged the battery, checked the oils, and a few other small things
after we felt safe w/ the setup, i got on the laptop and made some adjustments, and we did a few small pulls to make sure everything was in check
the first pull was part throttle and we saw 5 or 6 psi, but after Alex backed off the gas we got a few big backfires and the car ran like shit for a while, turns out we popped a pipped a pipe off, easy fix
a little later we got on it harder, and the boost spiked FAAAR beyond what we want .... 5psi is the target, the car spooled to 15 in a heartbeat .... but it pulled like a freight train and was still pig rich (11.2). no detonation, no sputters, just rock solid acceleration (14-16psi = well over 400 to the wheels )
after we pulled into the driveway i realized that there was a good size rip in the wastegate line. donno when or how it happened, but it easily could have happened at any point today or yesterday, after a quike fix we went back out to try it. turns out that we have 3 - 3.5 psi @ the manifold on a .4 bar wastegate spring. we got a short vid of us pulling down the 400 @ 3/4 throttle
then it was time to hit duffs for their car show. on the way down there was a newer tercel (i think) and the guys GF was staring at the SHO ... could see that she knew what the silver radiator and whistle were. she said something to her bf who was driving and he got all ****** off, and tried to pull ahead of us, so alex hammered on it, passed him, then backed off and blew off next to them. he did that a few times and eventualy he yelled "nobody cares" and tried to speed away again.
at duffs the car drew TONS of looks and ALOT of people came over to ask questions. alex and i were fielding questions for at least 2 hours, alex kept getting compliments on the work, and i kept getting compliments on the car in general .... we had to keep telling people "he owns the car, i just put it together" and vise versa
after that we hit up Mighty , hung out for a while, hit the airport tunnel for 2 passes, and headed home down transit
transit and genesee st, theres a 98 ****** on our left, and they are looking at the car like it ain't shit. passenger tells the driver "my buddy had a *inaudible* and it blew a SHO away"
hrmmm.... really ? light goes green, we start off light throttle in first gear, get it to about 3500 rpm and then alex just romps on it till 80mph, then backs off it and coasts back down to pace them.... blank stares from both of them, till they try to pass us .... haha yea right ....
the tried 4 or 5 times, and they just couldn't manage to get ahead ... wonder why ????
at one point i saw a hand signal inside the car, but didn't see WHAT it was ... turns out that it was the middle finger from the passenger ... he doesnt like us kinda ironic that he picked THIS SHO to talk about how slow they are ... they eventuly turned left at broadway & transit without ever laughing, smiling, or making direct eye contact
so that was our day, nothing realy exciting, but it was definantly nice to get out and feel that all our work was worth it
