tune up
MassSHO25
Webster, MA , USA
hey I'm new at this stuff, but what do i need for a regular tune up (not the 60K) as far as plugs and wires? I wanna get the parts but I wanna get the right ones, help would be greatly appreciated!! I am running a 93ATX and she needs a tuneup!
T
Tommy the Greek
Guest
How many miles on your SHO? If it has over 100K on it, and a 60K service was never done, consider doing it with the tune-up. You will definately see the difference. You will find many OEM parts for the SHO on the www.fordpartsnetwork.com - that is where I got my Spark plug wires for $139.99. Dealer's price - Over $300!
To start, here are the P/N's for OEM parts:
Wire set - WRE-4081
Spark plugs - AGSP32PP
FordPartsNetwork.com is the lowest priced source for the plugs and wires. The plugs are the Motorcraft AGSP32PP double platinums for $3.99 each. The Motorcraft WR-4033 wires fit both the 3.0L and the 3.2L engines for $83.99. These wires are a little tight from the rear bank, but they will fit and they have the cylinder number printed along the wires. The WRE-4081 wires designated for the 3.2L are $127.99 from FordPartsNetwork.com.
Scott
1991, 255K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/poly, Alum front SFB, SS front/rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
MassSHO25
Webster, MA , USA
its only got 70,000 on it, I wanna hold off on the 60k till the summer, but I will get it done, thanks for the help so far!
