mishman
SHO noises
OK, so I just replaced the flywheel, clutch, pressure plate, and throw out bearing on my 95 SHO with 111k on it. I recently started hearing a sound coming from the front driverside corner of the enginebay, most likely the transmission, that sounds like the balls of a bearing spinning around or a failing bearing. The sound is most noticable when I am driving a low speeds in 1st and 2nd gear, however it stops completly when I push in the clutch pedal, leading me to believe it is something with the transmission of clutch assembly. I would describe it as a "grrrrrrr" or grinding sound. I think it may be one of the input shaft bearings. If anyone has any advice I would appreciate it. My plan for now is to drop the subframe and take out the transmission to have a look at it.
