Transmission is DONE
x182dan
Seymour, CT
went to shift into third 2day and went boom. It went into third made a weird noise not grinding just a weird noise. Now its stuck in 3rd so I'm done with SHO's now. My car is an 1989 taurus and its not worth spending the probably close to $1,500 its gonna cost to get the tranny rebuilt or to find an used one.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Are you sure its not a clutch?
My friend just got a tranny from a junk yard for $83.
LOUDSHO92
Sponsoring Vendor
Im not sure, though when my staps went out it was incredably dificuilt to change gears, bascially had to force it. I have destroyed a clutch to the point where it wont shift.
The SHO tranny is pretty strong, so it usually doesnt go unless you have a lot of power or are abusing it.
x182dan
Seymour, CT
I didn't really push it my hardest but it seems like its stuck in gear pretty damn good.
LOUDSHO92
Sponsoring Vendor
Yeah it was stuck pretty goof for me too. It might be the clutch but I am not sure though.
x182dan
Seymour, CT
I should probably add this right after I went into third and it went boom I could wiggle the shifter all around like there were no gears at all i mean to left and right when it shouldn't be able to do that. Then I went into what I thought was 1st so it might be stuck in first for all I know it happened so fast I'm not sure
x182dan
Seymour, CT
its at the shop right now but because of holiday it probably won't be checked on till tuesday
x182dan
Seymour, CT
UPDATE: turns out its the shift cable I was told there are two of them? Its a dealer only item and they want something rediculous for them so I'm searching for a used one
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
actually, I had that problem happen to me, I grabbed a pair of locking pliers onto the end of the white peice at the trans and twisted untill it moved a little bit, that allowed me to reattach it, and shift without it popping off, I'm doing a rod shift conversion soon enough here, once I rebuild my engine, but it's definitly alot easier than trying to find a used one
x182dan
Seymour, CT
my mechanic is just gonnna try and rig it up he said it looks like it broke up near the shifter not near the tranny
jelloslug
Digital
Greenville, SC
To convert it to a rod shifter you do not need to remove the tranny. Rod shifters ron about $150 for a complete unit. You will need to cut the hole for it in the floor and install the different exhaust resonator, everything else is bolt in.
x182dan
Seymour, CT
its back on didn't even have to get a new cable he just put it back on the tranny and showed me what to do if it happends again
Devin
3.Slow
Pacific Northwest
Wow, that is a good mechanic. I'm sure there are plenty that would've told you you needed a tranny rebuild.
x182dan
Seymour, CT
I know this guy pretty well he only charged me $60 to fix it and he even put my starter in for me which I didn't even ask for he just saw it on the passenger seat and did that for me. And if he told me it was the tranny itself I would have junked it or sold it for cheap
