Tranny handing up into gears MTX WHY?!?!
1993MTXSHO
Its a Taurus...
Jersey
ok i have a 1993 mtx it hangs up into gears but isnt bad but for some reason 2nd is bad and so is going into 5th what coudl cause this and is there anything i can do about it? It did this with the old clutch and not i have a new one and its dogin the same thing.
dstig1
Hudson, WI
Did you change the tranny fluid with the new clutch (or ever)? Can help a lot. Search for recommendations, but I have been very happy with Mobil 1 ATF. You need ~3 qts.
SuperHO
Mental Patient
St. Joe, MI
Mine does that too when I'm trying to race.....high RPMs mean I have to put some ass on the shifter to get it in 2nd and 3rd.
SHOsFAST
Who's Running?
Colonial Heights, Va.
Syncros??check the fluid as well, I don't know about the SHO MTX's but some of them have a temper if they are not maintaned correctly.
SuperHO
Mental Patient
St. Joe, MI
Mine's got fresh fluid...shifts like a knife in butter when I'm driving normally....just when I beating on the car does it hang up.
1995mtxsho
Grand Rapids, MI
I have this issue also, I am relating it to my motor mounts being old and spongy, but doesn't yours have re-enforced mounts?
SuperHO
Mental Patient
St. Joe, MI
yup....FPS mounts, front and rear....tranny mount's kinda soft, though.
1993MTXSHO
Its a Taurus...
Jersey
i actualyl just had the trans fluid replaced with my clutch and my cars been maintained it hangs up even at low rpms the faster i try to put it in the more it hangs up if i go slow it will sorta slowly slide in.
1993MTXSHO
Its a Taurus...
Jersey
SHOwned213 said:
what kinda fluid did you use?
well i guess it had stock fluid in it b4 the clutch change and i had my mechanic replace it so i guess it has w/e was in it stock again why would a synthetic or anoth fluid help with shifts or is it really just keeping up on changine it?
AREA 91
PA SHO SHOP
Area 91
There are lots of opnions about which fluid to use, but I would change it out with a synthetic.
Amsoil ATF
Redline D4
Mobil One ATF
GM Syncromesh
These are just a few to choose from.
:thumb:
1993MTXSHO
Its a Taurus...
Jersey
Amsoil ATF
Redline D4
Mobil One ATF
GM Syncromesh
:thumb:
why do you say to change it out with a synthetic? does it help the tranny last longer or it might help it shift smoother? Also with almost 100k miles is it ok to go to synthetic, because I know with oil its known to start oil leaks when changed to synthetic at a higher milage. I just paid 40 bucks to get it changed if its not going to help I might just leave it in for a little although id be nice if it shifterd smoother :frown: Im also know to spend hours and lots of money to gain .5 hp haha so ill probably change it when it gets warm out.
1993MTXSHO
Its a Taurus...
Jersey
ohfosho said:
it could be a clutch cable in need of adjustment?
no I dont think so because the old clutch did the same thign I just got a new clutch so it was jsut adjusted.
1993MTXSHO
Its a Taurus...
Jersey
hey I don't know what this means but when the cars not running i can go through the gears perfectly smooth with the clutch out with no hang ups what so ever. So it only does it while moving does that change anything?
crazy_canadian
Rattle-Mobile
Quebec
you can do it in every cars.
btw, my car does it badly in fist and second gear too.
AREA 91
PA SHO SHOP
Area 91
Have you checked the clevis at the end of the rod shifter? You may have too much play, or it may be hanging up. Definately change out the fluid with one of the recomendations above.
1993MTXSHO
Its a Taurus...
Jersey
What is the clevis and where is that exactly lockated? Also I did jsut haev the fluid changed is is really worth burning the 40 bucks I just spent to get the synthetic in there?
laxmax327
philly
im not sure, but i just switched mine to mobil 1 atf after my clutch job. at first it wasnt any better. but now its def a bit smoother. not a whole lot. but definately noticable. before i sometimes had issues even getting it into first. i had to jsut start in 2nd sometimes. it hasnt done that yet. instead it just takes a bit more effort and it pops in. although, i recently noticed that i have also developed a leak. which kinda ****** me off cause i dont know what its from. it could be cause of the transition to synthetic. but i suppose i could have also nicked that seal around the axles. havent looked into it yet. will let you konw what cause of leak is soon.
