Traction issues
Report back after your first drive. Make sure you launch the car as well.
Brandon78
Ohio
They a
They are on! Hardest part was torquing them down lol...did you re-torque after so many miles. I did not add any new thread locker.
Brandon78
Ohio
Ok, no rain in OH. go out and step on it.
Yes yes please joke...but seriously wtf...I was not expecting this...still has the hop but seems like it is softer and spread out a little longer...idk how to explain. Does launch and pull better!
I don't know if you'll ever get rid of all the hop. Maybe stickier tires, wider tires, and playing with tire pressure. Stiffer springs and struts or coilovers. I guess it depends how much you're willing to throw at it and how much stiffness you want to tolerate in a daily car.
Brandon78
Ohio
Brandon78
Ohio
Do you or anybody have any in car launches...I would like to compare and see
Nova
US
Check out Jordan's videos he post on YouTube, he has draggy and go pro videos.
How is the sound? Also what are your front tire pressure? Drop them to 32 ish and let her eat.
Brandon78
Ohio
Sound is insane, I never would have expected that. I do have a little rattle some where sitting in Drive at idle. Currently the psi is about 38. I'll drop and see what happens. It just seems like I would loose alot of time from this wheel hop/stutter
Are you sure it is wheep hop or is it transmission shudder?
Have you done your 5 out 5 in trans fluid swap?
Brandon78
Ohio
With these in seems mor like tranny shudder and wheel hop, before it was much softer.
I did the fluid swap.
I emailed Anthony at...dare I say it....L I v e r N o I s e...to get his input
Get rid of that tune honestly. They are junk. Get with Gearhead, AJPTurbo, or Ortiz.
ridered74
Did you overfill transmission by half a quart? That will be step 1 from them.
Brandon78
Ohio
Checked probably 24 times in the process of doing it. Was at a good level, got it to operating temp and checked another dozen times. Pain in the ass with the windstorm intake
Brandon78
Ohio
Step Two: Buy our Firestorm HPFP.
My trans is filled to stock fluid levels. I have zero issues, and I have a VERY spicy tune.
He said we can try a different tune. And check tranny fluid and he recommends over filling about a pint...I dont really like that idea
markmoomnu
