Report back after your first drive. Make sure you launch the car as well.
Ok, no rain in OH. go out and step on it.
I don't know if you'll ever get rid of all the hop. Maybe stickier tires, wider tires, and playing with tire pressure. Stiffer springs and struts or coilovers. I guess it depends how much you're willing to throw at it and how much stiffness you want to tolerate in a daily car.
Check out Jordan's videos he post on YouTube, he has draggy and go pro videos.Do you or anybody have any in car launches...I would like to compare and see
How is the sound? Also what are your front tire pressure? Drop them to 32 ish and let her eat.Yes yes please joke...but seriously wtf...I was not expecting this...still has the hop but seems like it is softer and spread out a little longer...idk how to explain. Does launch and pull better!
Me tooI’m on the list...
Are you sure it is wheep hop or is it transmission shudder?Sound is insane, I never would have expected that. I do have a little rattle some where sitting in Drive at idle. Currently the psi is about 38. I'll drop and see what happens. It just seems like I would loose alot of time from this wheel hop/stutter
Have you done your 5 out 5 in trans fluid swap?
With these in seems mor like tranny shudder and wheel hop, before it was much softer.
I did the fluid swap.
I emailed Anthony at...dare I say it....L I v e r N o I s e...to get his input
Did you overfill transmission by half a quart? That will be step 1 from them.
Step Two: Buy our Firestorm HPFP.
My trans is filled to stock fluid levels. I have zero issues, and I have a VERY spicy tune.
