top end ticking sound...just started :(
Cocoa,Florida
i just fired up my 91 a little bit ago,and i noticed a noise.
so i poped the hood..and tick tick tick tick tick tick tick tick!!!!!!!!!!!
must have just started sounds like its coming from the
rear bank,center cyl.intake side.just about where the "valve thingy" the opensthe secondaries is any one have any ideas????
sound changes with the RPM,car is full on oil,just did a change
3 days ago,never runs hot,oil light has never come on.
no C/E light no power loss. :cry:
i have a feeling this is gonna get expensive :frown: :frown: :frown:
platoribs
Live to Drive
Plat0ribs House of SHO,il
My 93 has sounded like a bomb since I picked it up in 1997 with 40K miles on the clock. At 150K miles now and it still pulls strong... no SHOboom yet!
GreatHumungous
Im Kenny Rogers
Newark, Ohio
Your car ever had the valve ajustment? Does it run rough? You said it was coming from the rear around the "valve thingy" that opens the secondaries. Do you have any vacuum leaks around there?
SHO#7
Cincinnati
Did you use a mechanics stethascope to find the noise. You may have a chain tensioner ready to fail. They will often times let the chain hit the top of the valve cover, making a rythmic tap noise.
They are not hard to change. Hard to find, but not change.
Mike
Cocoa,Florida
ive never done the valve adjustment,but someone else may have
otherwise the car sounds good and has great power,the ticking is coming from the one
area not the whole motor,as would be with a valves out of spec
i guess it could be the chain tensioner,but i dont think so,it really sounds like the center,rather than off to the side
keep the ideas coming guys/gals!!!!!!
SHO#7
Cincinnati
I would get a stethascope and find where the noise is coming from. I have bought 180k SHO's with valve shims way out of spec, and they were not loud. I have had tensioners STB and they would make all types of noise. You really need to pinpoint the noise. Unless it spit a shim, I doubt that is your noise. But that is just my opinion. Get the cam covers off and look.
Mike
Cocoa,Florida
sad thing is i just had the valve covers off last weekend,doing gaskets and plug
tube seals,everything looked fine then....i guess ill do it again sighhhhhhh
do you think i can see the problem once the covers are off?
is the anything specific i should look for?
what does a worn tensioner look like,compared to one in good shape?
what if i have a broken valve spring or somthing like that will i be able to see it?
SASHO91
Zoom Zoom
San Antonio,TX
well yeah i broken valve spring would look..... well broken....
if the TCT is bad, it might be grooved from the chain...
i have also heard of them getting stuck... and a quick shot of air in the bottom would fix that problem.... allthough im not sure if that works....
you can reuse those gaskets.... if its only been a couple weeks... **** even a month.. you could still reuse them...
SASHO91
Zoom Zoom
San Antonio,TX
well, see the injectors make a ticking sound when they are running...
i guess you could try to see if one is making more sound than the others, but i highly dought that though... take a long screwdriver, snd put it on the injector, and put your ear to the screwdriver... you should hear a noticeable tick....
but like i said, i really dought thats the problem...
Cocoa,Florida
its just really strang,because the car is running perfectly other wise
pulls very strong,no miss...nothing,i guess ill take it appart this weekend!
1stSHO
Asian Lover
Fort Walton Beach,FL
How loud is it Brian????
It might just need a valve ajustment!! Remember, she hasnt been run hard in a long time. I see you have already had my baby to the track, so it might need the valves ajusted.
Gosh, i sell her and now she is acting up.
Cocoa,Florida
hey guys i found the problem....get this!
i was doing a little reserch and found that somthing in the
secondaries can cause this noise,and it said in order to check you must unplug
the little electrical connector that leads to the canister....so i did so with the engine running
and.....**** noise was all gone!!!!!!!!! but as soon as you plug it back in the noise starts right back up,right now i have it unhooked,but when it is hooked up the secondaries work fine....anyone know what it is i need to replace in order to fix this?
if it helps when i did the valve cover gaskets last week,i also instaled a set of BBB's i had
1stSHO
Asian Lover
So with that thing unplugged it dont run as good with it plugged in???
WOW, ive been driving it with little less power than normal!!!
Glad you fixed it :thumb:
SeanMc
NoMoSHO
Hmm, I may be having the same issue (at first it sounded like a timing belt tensioner). I have a tick, but the rhythm doesn't increase with RPMs, just gets a little louder, and goes away when the 2ndaries open. I'd also like to know the solution.
Cocoa,Florida
do you have BBB's on your car?
i bet its the same problem!
Cocoa,Florida
have you tryed doing as i said above,disconecting the wire
that hooks to the secondarie system?
try this,if the noise stops then you have the same problem!
i just need to know what it is i need to replace to stop the sound
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Remove the butterflies :biggrin:
