TONS of performance parts - Parting 95 silver MTX
Donut Boy
Jersey
UPDATED 11/04/2014
Email me at [email protected], call me at 201-838-9828, or PM me.
SERIOUS INQUIRIES ONLY!!!!!! Thanks!
Engines & Engine Components
Ported and gasket matched 3.0L heads with stronger than stock valve springs (no cams) $375 obo
3.2L MTX (available as short block or long block without cams (block is painted red))
Short block will bolt directly into MTX cars $400 obo
Fidanza lightweight aluminum flywheel $200 obo
Suspension & brakes:
26mm rear swaybar $75
11.6” rear big brake kit (new) includes cut Porterfield 11.6” rotors, 89-92 rear calipers for larger vented rotors, new pads and new caliper hardware, new spacing rings, brackets & bolts. Also includes rear caliper to spindle mounting plate. (will require rear hubs to be removed and will be necessary to replace rear spindle dust caps and abs rings.) $375 obo
Turbo kit components:
2x new Mitsubishi turbine inlet weld-on flanges $35 each
2x SHO new exhaust flanges (to fabricate turbo manifolds) $60 each
Driveline components:
Driveshaft Shop stage 5 axles with abs rings good for 500+hp $900 obo
Quaifed 5-spd transmission (transmission needs new bearings and 2nd gear blocking ring) also has reinforced rod-shifter mount boss $1400
Stock 5-spd transmission in good working condition, no grinding, no noises $500
Stock 5-spd transmission in need of rebuild (needs blocking rings, no bearing noises) $350
Rod shifter $75
Electrical/Interior:
MSD DIS ignition system with 2 tach adapters $500
Superchips X2J chip $125
Wheels:
18” Mille Miglia Evo5 rims (minor curb marks on some of the wheels, needs new tires) $400
16x7” Borbet Type F wheels, almost new Dunlop SP8000s, includes hubcentric spacer rings $350
jayro
Auburn, In
PM sent on Stainless Brake lines and Throttle body.
Jeremy
Donut Boy
Jersey
I need to sell this stuff as soon as possible.... I will entertain any reasonable offers....
