TOB sleeve. Where?
Crab Spirits
Chicago
Where can I get the steel sleeve for the upgraded throwout bearing? My clutch came with the larger bore TOB, but no sleeve :shrug:. The "tech tips" that came with it say to get it from napa. So I go there and the guy doesn't know WTH is going on. Do other parts stores carry this?
AREA 91
PA SHO SHOP
Area 91
I have not been able to buy just the quill sleeve seperately.
You have to buy the Revision B throw out bearing. It comes with the quill sleeve.
You need to use Green Loctite to retain the quill sleeve.
Crab Spirits
Chicago
What clutch kit did you buy?
I was GIVEN a Napa clutch kit.
The throwout bearing fits very loose. I went to Carquest to see what their TOB looked like. When the guy brought it out, the box contained 2 sleeves and NO TOB, lol. So the guy was just like "wth is this?" and gave me one of the sleeves. I tried it on the trans and it seems like it will fit if I pound it on (not sure if this is correct). However, the sleeve does not fit in the TOB. So I called every parts store in the area and they are all out of stock on the TOB/TOB kit except an Autozone an hour away. Go there, and the guy had nothing for us.
:thankyou:
shotime1994
AirHammerAndrew
New York
You should just buy the ceramic t.o.b form shosource it comes with everything you need.
