To resonate or not to resonate
Rayme20
I did the resonator delete on my SHO. In my opinion it didn't make any difference in sound or performance, but when I added my magnaflow cylinder your mufflers the car is SUPER loud. It sounds fabulous on the outside, but too loud on the inside at 2-3k rpm. I have tried foam in my trunk, made no difference. Was wondering if anyone had any ideas. I thought About adding back a resonator, but I don't want to hurt my performance.
Rayme20
I didn't have the magnaflow mufflers when I took it off with the stock mufflers it was the same
bigscot
I tried a few different setups on mine to eliminate resonance at 1850 rpm (or 92.5 Hz) which is right at 70 mph.
1. Started with muffler delete which sounded really good, but had too much resonance at 70 mph..like way too much.
2. Next step was 3rd cat delete, resonator delete, and a set of knockoff flowmasters. Sounded different, not quite as good as the muffler delete, but still lots of resonance at 70 mph.
3. Third step was to add resonators back in. Put two 18" resonators in and the resonance was tolerable, but still obnoxious. Car still sounded good.
4. Added a short h-pipe just behind where the 3rd cat was. This had the effect of lowering the resonant frequency to around 1700 rpm and increased the roll-off (higher Q) around that frequency. Resonance was still annoying ay 70 mph.
5. Replaced chambered mufflers with Summit Racing turbo mufflers. Now the car is quiet again, no interior resonance, but a little too quiet for my tastes. I really like the Summit rolled steel mufflers because the internal flow tubes are 2 1/2 all the way through, not necked down inside like so many others.
I'm planning to replace the hacked in h-pipe with an x-pipe in an attempt to increase the sound level just a bit. I'm definitely keeping the turbo mufflers on it. I might pull the resonators back off because these turbo mufflers just might be quiet enough. Or maybe better yet I'll put some downpipes on it...hmmm
Why did I do all this? Because I've had the chance to hear the different setups and it cost me maybe $400 all together to really get a feel for what I want, and im still $1,000 away from the corsa system, which I don't think I'd be happy with (it'll be $700 away by the time i'm done...lol). If you drive around town all day the muffler delete is a great option and sounds good. If you spend time on the highway, I personally wouldn't recommend chambered mufflers.
Dwayne614
I want to delete my mufflers but people told me in the long run I'll have issues. Have any of you had any issues with a muffler delete?
bigscot
Won't affect the performance if that's what you mean. Have a look at the head pipes coming off the converter where the 2 1/2 inch pipe is crushed in half for clearance. Nothing you do cat back will have any real effect.
SilverSH0
I put on new AR25 resonators in place of the mufflers and they sound great outside. Inside, drone from about 2200-2800 rpm. I'm currently in the process of fabricating some helmholtz resonators to eliminate my 125 Hz drone. Hopefully it works as I expect.
Dwayne614
My coworkers(mechanics) were telling me I may have motor issues with the mufflers gone. Not really looking for performance I just want drone
Dwayne614
If i delete the mufflers add an X pipe + delete the resonator and the third cat will I have any issues?
Issues meaning mechanically
lingyuair
