ffemtcurrence
Clutch
ok 2 weeks ago a coolant line split open and my engine got hot so i fix the leak and ever since then my car has been missing, sputtering, and completely junk...so earlier tonight i took apart and cleaned the IAB/IAC Valve "the nostrils" and the throttle body...and wow no more codes no more stumbling and lots of power....well after driving around for an hour i come to a stop light and what do you know another coolant leak (not near water pump, bit the hose under the throttle body) and my car is now throwing codes again and stumbling and the strong smell of gas...so my question is how would leaking coolant basically **** the performance of my engine....so tomorrow do i have to take apart the iab again which to be honest was a pain in the butt and clean it...or what this is really driving me insane..i mean a 3 hr job destroyed in an hour....
the codes were
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control
181 (M) Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
412 (R) Idle speed system not controlling idle properly (generally idle too low) - ISC
i have new o2 sensors on, and like i said after cleaning the valve every code and problem disappeared...please for the love of god :thankyou::thankyou::thankyou:
the codes were
