How confident are you that the dealer that did the service actually measured the tread depth along the life of your tires, or just had the oil change guy look and say "eh hes got 5000 miles on it, 8/32 is good". Happens more often than you think.
That would be their problem then.
My thing is how all of sudden did my tires start wearing extremely fast about 2-3,000miles after they messed with the front end for multiple days. On top of replacing tie rod ends the 'engineer' did this.
Field engineer road tested car and verified noise.
Raised vehicle on alignment rack and atempted to pinpoit noise.
Listened to complete front end with electronic stethescope.
Noise sounded loudest in kuckle and strut area.
Removed lower controll arm and checked ball joint for binding.
Removed steering kuckle and pulled out wheel bearing.
Inspected wheel bearing.
Applied anti sieze to bearing boar and reinstalled bearing.
Removed strut.
Removed strut cap and bearing assembly.
Inspected bearing and repacked.
Reassembled front end.
Engineer road tested Taurus, noise was gone on left side that was apart.
Performed same procedures to right side of vehicle.
Disassembled left suspension and reassembled.
Road test vehicle both sides now quiet.
Performed front end alignment check.
Reset toe.
The three service sheets I have after they did front end work (from 7,000 - 10,000) all note that there is uneven wear on the front tires of the vehicle.
I'm not trying to get a set of wheels out of this.... Not even close. I want to be assured that the front end of this vehicle is ok. If it turns out that it isn't ok, then I expect the tires be prorated for replacement and that the front end of this vehicle be fixed to avoid further issues.
I just find it way too odd that Goodyear and other Ford dealers say those tires should last 18-20,000 miles and mine were on pace to doing that until Ford toyed with my front end.
We'll have a verdict 9am tomorrow morning.
