timing chain
9
97shobroken
Guest
ok idk what you would call it, but the thing so you can put the car in time with the timing chain its like a diagram on how to put it.im not in need of it right now but i want to have every thing together b4 its getting touched..
naval-avi8or
Chesapeake, VA
Are refering to a tool or a graphic of how all the timing marks align.
Only tool is the cam alignment tool and its nice to have (I have a set) but isn't required.
As for the diagram of the timing marks you can get them from any manual and they will probably confuse the $^&* out of you. Top dead center #1 alingment marks for each cam/head is set perpindiculer with the respective head as well as all black links on the chain will match up to each pully/timing gear. The gothch is the tone ring some are generic and have two key ways approx 135 deg apart you pick the wrong one and youget to take it apart and try again. So when you dissassemble mark the tone ring.
9
97shobroken
Guest
well the diagram would be best . and yea i understand what you mean thats y im askin for a diagram.. becuz i had one b4 like 2 years ago and lost it, and would like to get another one if some one has one or knows were i could find one with out buying a Manuel cuz i dont need it......
Mr Anonymous
Tire Wall
All you need to do is set everything at cylinder 1 TDC and then just hang the chain with all the colored links aligned to the dimples with the exception of the balance shaft where the two colored links straddle the dimple. Takes about 2 minutes. I usually recommend starting with the balance shaft first since everything else will fall into alignment pretty easily that way.
The only tools we use from the V8 toolkit are the valve spring compressor, compressor brackets, and tappet holder. Everything else is pretty much useless.
naval-avi8or
Chesapeake, VA
http://www.v8sho.com/SHO/TimingChainMarksQuestion.htm
If you need a different one just email me [email protected]
Oh and I hope you have a protractor.
