Great, not eactly what I wanted to hear, but thanks. One question, I pulled the front valve cover and bumped the starter, the whole timing chain that drives the cam is not moving either, so is the actual break someplace else than the cam? I understand what you are telling me, and I expected to see a broken cam, but was surprised that the timing chain wasn't moving either.
Next question, what does it typically cost to have this fixed?
What I did was remove the front valve cover (well, lift up actually) and while having someone bumping the starter (the motor does turn over freely) watched the chain and sprocket on the passenger side of the engine compartment while the motor was turned over. This is the chain I am refering to that did not move. Is the main drive sprocket on the driver side of the motor? Was I looking at the wrong side? At the time, seeing that left me rather peeved and not wanting to look anymore. The motor will run as it is, albeit very poorly.
