Ticking heads.
Joe_SHO
ND
I have a 94 ATX. It has roughly 116k on it, and I highly doubt it has ever had the valves adjusted. From what I can tell it runs pretty good and it shifts quite smoothly, but the heads seem to tick a lot. I'm not sure how much is normal. Could this be excessive valve clearance? Thanks. -Joe
Vnuk1
Mr. Mayhem
Minnesota
Might be the cam chain tensioners, the chains slapping the valve covers. Get a screw driver and put it on the end of the valve cover where the tensioner is and stick your ear on the handle end see if you can hear anything. If the chain is hitting the cover you will know, and maybe just give it a little gas until you hear the sound.
quikSHOilver
Yamahaized
Indy
timing belt tensioner?
Since yours an ATX you might want to check out timing belt tensioner... it operates by self contained hydraulic... when it gets worn out and lose hydraulic pressure, It will start to make ticking noise. I had same problem at 130k. I thought it was upper head area until narrowed down to middle of engine. Hope that helps.
matt59
Simi Valley, Ca
Have you found the source of the ticking?
I ask because my 93 ATx does the same thing.
At about 1000 to 1500 PRM the tick is noticeable.
Also when I let off the gas I hear it from the timing cover area.
I'm sure it's the timing belt or tensioner.
What did you find?
Thanks... :)
ultimatesho
Fort Bragg, NC
also mite wanna make sure its not just ur secondary butterflies chattering around........95's intake dose this had me scared for a while it was the rod bearings till i got to lookin deeper
to check it all u gotta do is disconnect one of the vacuum lines of the black canister connected to the rear of the intake (just to test to c if thats the problem).....cant remember which one rite of hand tho
Joe_SHO
ND
Have not found it yet. My car is overwhelmed with problems. I'm hoping it goes away after I do a 60k this summer.
