thinking high compression on TurboSHO
TRicker
Minnesota
are you using a turbo correctly sized for your power level, or are you running something capable of much more? big turbos can suck, and many people buy a turbo a couple sizes bigger than what they really need for "someday" and just end up having an inefficient turbo for their application. every noob knows that big turbo=lag but really you could run a slightly smaller turbo, and turn up the boost a tad. or run a dual ball bearing turbo if you dont' already have one. this isnt a cheaper route than building a motor over again but it's gotta be more painless.
HotRodKid
mmmmm ... turbo
Western NY
its already dual ball bearing
and this turbo is sized just fine for what alex wants to do with the car :)
somedude_001
Western NY
you are right on one count. The turbo I bought for my SHO (taurus chassie) is a bit on the large size. I should have used a GT35R instead of my PT67, BUT I alway had plans that would max out a GT35R in a RWD setup so that is the seccondary reason I went with the PT67. The primary reason was that the GT35R was on a 6 week backorder at the time. My RWD project will be comming close to maxing out my current turbo and I will likely buy a GT35R to fill the void in my turbo pipes on my taurus. If I don't do that I will be spraying enough NO2 to get me into the low 12's.
HotRodKid
mmmmm ... turbo
Western NY
^^^that would mean:
"vehical 2"
+all turbo parts
+all nitrous parts
+fucillo exhaust
+cams and pistons
+ some stuff i have planned for the 240, that would work here too (dont ask)
shobroooo
