The 94 is having some fairly major issues
audia65spd
connecticut
ok so we had some problems with the 94 first off we put new spark plug wires on it last nite(idk if that really means anything but o well) ok so what happen was my bro picked me up from school in it and when he jumps on it..it would go good till 5 grand then start to buck so ok he doesn' jump on it again...then we are on our way home just going nice and slow 35 or so on a back road....and the car starts to buck again, we think maybe one of the plug wires is lose so we check all of them and one was not in all the way...so we push it in let the car sit for 45 mins or so start it up runs good...then we leave to go to a car show. and my bro jumps on it again and does the same thing at 5grand so we don't jump on it anymore..we are going down the highwau just at 70 in 5th gear....car starts to buck again this time it is REALLY bad the car is shaking also the tach is all over the place..so we get off the highway and are sitting at the light waiting and it keeps stalling
and it is idling like shit....then we get going it is barely running at this point tach is all over the place we manage to get it into a parking lot and park it. we stop it and it starts runs for 5 secs the dies... we are thinking it is either a CPS or CID any thoughts would be apperciated. one thing every time it did the tach was all over the place
kmetros
Drug Pusher
South Bend, IN
Are you sure you installed the new plug wires properly? Note the difference on 4-5-6 on the coil pack. Did you use dielectric grease on the ends of the wires? Are you sure they are all seated properly? Did you knock something loose on the back side of the engine when you changed the plugs? It's likely to be something with the plugs since you changed them the night before this happened.
Also, grammar is your friend. Use things like caps and periods, it gives the reader less of a headach and they are more likely to actually read your post and reply. :)
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Sounds like the CPS to me. Check your codes, but I'm pretty certain that you'll be tearing into the front very soon. Use this websites instructions on pulling the codes. . . . . http://www.shophoenixproject.com/eec/eec.htm
