NotSoSlowSHO:
haydenm315:
projectSHO89:
The fan should kick on at about 210 degrees when the car is NOT moving at an adequate speed.
Steve
That seems high to me. I thought that our cars use either a 180 or 190 degree thermostat depending on 3.0/3.2 I don't know much about thermostats, but my guess is that 190 means thermostat will open at 190F. Someone please explain this to me if I'm wrong.
haydenm,
Youve got part of it right.
the coolant system has two different limits, minimum and maximum operating temps.
T-stat regulates the MINIMUM operating temp. The t-stat stays closed, until operating temps reach 180/190. Then it opens and allows the coolant to circulate from the block, to the radiator, and back to the block.
The fans turn on at certain temp (about 210 as stated) to regulate MAXIMUM operating temps. The fan relay recieves a signal from the coolant temp sensor at a set temp, then activates the fan(s).
Make sense?
