Temperature Gage Not Reading
ndetello
Oklahoma
Still trying to sort out my first SHO. The temp gage does not move at all. Whats the better odds - gage or sending unit? Any way to test either one?
projectSHO89
SHOless In St L
Verify wire is plugged onto the sender.
If it was okay, disconnec it and short it to ground. TEMP guage should then go to full scale. If it does, the sender is probably open.
If the guage doesn't move, the either it or the circuit to it is open.
Steve
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
where is the temp sender located?
edit: wow didnt realize i originally had TEMP gauge... (uhm isnt that the thing in front of you when youre driving? :p)
SolidState
No Mo SHO
Toronto, Ontario, Canada
directly above the thermostat on the thermostat housing....follow the upper radiator house under the TB towards the valley for find the thermostat housing...
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
Thanks man, should i change that if im already changing my thermostat? ive heard if the sensors go unchanged the car runs in rich mode and then decays the cats...
Redskull
Badass Mo'fo
New Haven, CT
I would say replace all three: thermostat, gage sender, temp sender. all three will probably be less than $30, and it takes about 20 minutes to replace them.
Better safe then sorry, especially when cheap
projectSHO89
SHOless In St L
That would be the ECT, not the guage sender. Different units. THe ECT has a rwo wire connector and is located more towards the firewall on the water outlet housing.
The guage sender has a single wire and is the forward sender that is screwed into the outlet housing below and slightly forward of the thermostat tube.
Steve
