Sync BT issues
04lss
Hello,
Other issues with my car aside, my phone will no longer connect via blutooth to sync. It started off as just not connecting for media. Ive tried un-pairing sync on my phone, ive tried the factory reset on the radio.
My phone connects completely fine to all of my other BT devices including the radio in my other car.
Any ideas?
krewat
Long Island
Unpair, both from the car, and from the phone.
Disconnect the battery and wait for 15 minutes. Even a "master reset" doesn't necessarily completely reset everything, I've found.
In my many trials and tribulations with my 2013 with Sync MFT 2, I found that disconnecting the battery cleared up certain things.
Also, what version software are you running? What phone?
04lss
Thanks for the advice just unpluged the battery.
Samsung galaxy s7 edge,
SW version b4u12007
04lss
The battary reset seemed to have worked. Took a while for everything to settle and start working again.
BoatSHO
SE Michigan
On my 2013, I started having some weird issues with the MFT system (Phone wouldn't connect, system would not switch between inputs like FM, SiriusXM, CD... volume **** would not work). It actually showed up right after tuning, so I suspected that. But I was totally wrong. I went onto the Ford SyncMyRide website, registered my car. Found that it had a update...you download the update to a USB stick on your computer. Walk out to your car, plug said USB stick into your center console USB port. Follow the instructions. Super easy. Once I installed the latest update, the MFT has been flawless. You may want to register on the Syncmyride website and enter you VIN etc. See if you need/have an update.
04lss
I just checked and according to the sync website, there havent been any updates since may 2010.... The level of service ive come to expect.
no that's not right - they had a major update mid-13 and that fixed a lot of issues as Angela pointed out above.
glockcoma
This is what the site shows.
Just checked mine lol. Also says its up to date.....
I would stop and see the dealer's service department, because there have been several Sync updates since 12/2009.
jbeez
Pennsylvania
Try disabling wifi on your phone, then get in and start the car, see how it goes. I used an app called a2dp volume on my android phone that auto disables wifi when it starts connecting to the car and fixed a ton of my issues
brucelinc
Minnesota
There has been at least one update for sync for the 2010 models but there have been more for vehicles with MyFord Touch. The ones for MyFord Touch are not applicable to cars without that interface.
