Has anyone else had phone volume issues on Sync 3? Probably more than half the time, I have to turn the phone volume up to 30 to even hear it, and then calls are barely audible at highway speeds. The stereo, ringers, Sync voice prompts, Bluetooth music, etc work fine. You can disconnect Bluetooth and reconnect, and it will eventually have normal volume levels in phone calls. Sometimes it takes multiple disconnects and reconnects to fix it. I’m using an iPhone X on iOS 12.0.1. I’m trying to figure out if it’s a phone issue or Sync. The phone was just replaced by Apple and is brand new, and the old phone did the same thing on iOS 11, so I’m thinking it’s probably a Sync issue.
It’s really annoying since I have to make a test call to my voicemail every time before making a call to make sure I’ll be able to hear it and it’s a crapshoot when I answer a call whether I’ll be able to hear or not.
