Switched EGR, but still no change, and 332 code..
SHO SPD
SHO member #480
Naples, Florida
I unpluged the lines, and there is still vacume,so its none of that. could this EGR be faulty? Please help!!!
SHOfun 93
Euless, Tx (Fort Worth)
Did you change the DPFE on the rear bank on the intake? That is what sent my 332 code on mine and now it is okay..did you clean the EGR nostrils? I tried that first and still didn't solve the problem but check those and see if the code leaves...good luck..
projectSHO89
SHOless In St L
Do a search on "332" and my member #. I posted a complete diagnostic on the 332 several months ago.
Steve
89
Have you blown through the lines to verify that the entire path is open? There is a clean out plug on the rear of the intake behind the EGR ****** that lets you stick a hose in there and blow through to the intake nostrils. If the 332 code is showing in the memory section (after the separator pulse), have you cleared the codes by running the test and pulling the jumper while the codes are being displayed?
jthomas68
Area 51
And while you`re at it,can you still make me just the white faced tach?Let me know via e mail or PM on here.Thanks Matt.
