Supporting Motor
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
What is the best way to support the motor when im dropping the subframe? should i use my engine lift or something else i saw some people had built engine supports... how would i build one and/or if someone has one could i borrow it for a couple months?
thanks in advance
Force4
Guest
Wisconsin
thick wood that can reach across your frame. Either X Shape or w/e works. ask dave he did it on mikes motor.
black92
Wisconsin
A 2x4 or a 2x6 should be fine. Run to the hardware store and buy some chains and brackets and wood.
Wht91+
93 Green MTX
Oconomowoc,WI
Thanks Chris. yeah its not that hard. all you have to remember build it to last "its supporting your motor" :thumb:
RAYJAY
WHO ME ?
UNION DALE PA
if you do a search on the site you will find some post on how to make a motor support
Jeff
this is a repost from the site
SHO ENGINE SUPPORT BEAM
Made of 1 1/2" galvanized steel pipe, this beam is more than adequate to support the engine and is useful if you want to drop the subframe or remove the engine and/or transmission. It is tee-shaped with a rear beam across the engine compartment with a hook and chain going through the rear driver's side lower inlet manifold support bolt, and a tee beam that goes from the rear beam, over the lifting eye (attached to the beam with another hook), and rests on the front cross member.
Cost of parts around $25. All parts from your local hardware store.
Assembly time around 1/2 hour.
Dimensions are for both Gen I and Gen II.
PARTS NEEDED
Rear Crossbeam: one length of 1 1/2" o/d (1 " i/d) galvanized pipe that is 54.5" long for a Gen I or Gen II. Have the store thread both ends. You need to be accurate on this measurement as the feet rest on the hood gullies which are only 1" wide.
Tee beam: one length of 1" i/d galvanized pipe 32" long. Have the store thread one end. This gets bolted onto to the rear beam and extends to the front of the engine compartment over the engine lifting eye. This is around 1- 1.5" longer than you really need, but you may want to use this on other cars, so this way you have a bit of flexibility.
Then from the parts bins:
- Three 1" to 1/2" elbows to attach the legs.
- Two 1/2" pipe sections (threaded at both ends), each 3" long for the crossbeam legs.
- One 1/2" pipe section (threaded both ends), 4" long for the T leg that sits on the front cross member.
- Three 1/2" tee joints for the feet.
- Two 8" long eye bolts with the correct nut and washer which are used to support the engine. You will need to open these up in a vice so that they become hooks. Eye should be around 1.75" outside diameter. They will need to be 8" long to enable you to tilt the engine when getting the transmission out.
- One 12" length of chain with links big enough to go through these hooks and through an inlet manifold support bolt. This is used to support the rear of the engine by removing the inlet manifold support bracket nearest the driver and using the lower bolt as an anchor point for the chain.
- One 3.5" X 3/8" bolt with nut and two washers to join the T to the crossbeam.
- Thick Pads of some kind to go under the crossbeam feet. I use leather coasters. Thick shop towels will also work.
TOOLS NEEDED
- Electric drill, drill bits for the hooks and 3/8" bolt.
- Hammer and center punch to stop the drill bit wandering when you drill the holes.
- . A 1/2" socket drive extension bar used to tighten the elbows and tees.
- Large vice.
ASSEMBLY
You may want to use Loctite:
Attach the elbows to the ends of the 1" pipes.
Attach the legs to the elbows. The short legs go on the long pipe, the long leg goes on the short pipe.
Attach the tees to the legs.
Drill holes for the 8" long hooks and the 3/8" bolt. It's best to put your bars on the engine compartment, long one across the back behind the inlet manifold, short one roughly at right angles to the long one so that it rests on top of the crossbeam, passes directly over the engine hoist eye and the foot rests on a flat part of the front cross member. One hook is passed through the lifting eye. The other is attached to the lower manifold support bolt I mentioned earlier. Now you should know where to drill the holes.
Attach the Tee to the crossbeam using the 3.5" bolt and a washer under the nut and the bolt head.
Attach the hooks to the beams. Washer under the nut.
INSTALLATION
Take off the inlet manifold support bracket nearest the driver. Place the support beam in position. Use plenty of padding under the feet. Remove the front hook, pass it through the engine lifting eye, and put it back on. Take up the slack by screwing on the nut until it is finger tight.
Attach one end of the chain to the rear of the engine using the lower manifold support bolt where it goes into the engine block. Don't use the upper support bolt: you may put too much strain on the inlet manifold.
Make sure that the rear hook is near it's highest position (nut screwed almost all the way on), then attach the other end of the chain to the rear hook. Take up the slack by screwing on the nut until it is finger tight. Make sure you use shop towels to stop the inlet manifold from being scratched.
You are now ready to begin work on removing the subframe, etc. You will be able to lower/tilt/raise the engine by adjusting the two nuts on the hooks once the subframe is removed.
Make sure that the engine is supported from below after removing the transmission as a safety measure.
NOTES FOR THOSE FOLLOWING THE CLUTCH VIDEO INSTRUCTIONS
Skip Steps 13 and 15. No need to remove the intake manifold crossover tube and wiring harness bracket.
Nick Chrimes
Wht91+
93 Green MTX
Oconomowoc,WI
Jeff
that works:thumb: as long as your not swinging like a monkey from the motor it will be fine :thumb:
