Supercharged SHO Dyno
leerocketmike
Mikegski
Texas
Another boosted SHO.
3.0L
Vortech S-trim 10psi
Air to Water Intercooler
BBB
Ported Throttle body
Equil Length Catless Y-Pipe
3in Exhaust
DynoMax Muffler
And a 75 shot
I laugh in the video because they asked me what I thought it would make and I said 375.
http://youtu.be/MZMeonvS8Dg
Made 374 on motor and 418 on the bottle
2ndDyno zps25c6e398
DampG zps529c1d4b
leerocketmike
Mikegski
Texas
What else has been done to that car? Stock 3.0 pistons?
Nice numbers.
Thanks
I'm not sure what clutch is in it but I'll be putting a CMIII and a fidanza in it, the clutch feels really soft but was impressed that it held with no problem.
Stock pistons and a little tlc...
frosho
WOLFMAN
Tyngsboro, MA
Thanks
Does the CM3 have higher-than-stock clamping force? Some people have shifting issues with the Fidanza/HD PP combination. The flywheel flexes due to the higher forces exerted on it and doesn't completely release the clutch disc.
89SHOMAN666
SHO NUT!
Reading, PA
You are correct the CM3 is a dual diaphragm pressure plate, and other members including myself have had problems coupling it with aluminum flywheels.
leerocketmike
Mikegski
Texas
http://youtu.be/l43XU_lDixg
If you rememeber my old car Slo Sho made 494hp with no issues with a CMIII and Fidanza. I have heard of some people having problems but I have had great success with them. My Procharger setup made 395hp with a Fidanza also...
kevinspann
Don't take my advice.
Richmond VA
The supposedly dual diaphragm spec clutch with an aluminum flywheel was junk. Ruined the insert, the clutch, and the pressure plate friction surface had multiple cracks.
thatSHOguy101
