94 Taurus SHO ATX Auto 3.2 Opal Frost Gray Interior - All parts off car with new photos!
Form1le
Lansdale, PA
Open to offers on everything, so please PM me with needs. Thanks
Parting out 1994 Taurus SHO ATX Auto 3.2L. Car & engine had 230K+ miles so please take that into consideration as I’m selling all parts AS IS with no returns. New parts listed below have virtually no miles as I only drove the car a few hundred miles. Car was scrapped. Exterior Opal Frost, Interior gray leather. I’ll try to include mounting hardware where I can. I listed the big stuff, but if you don’t see something let me know. Prices do not include shipping. I can’t ship the big stuff, sorry. I’ll start a separate section below for what sells. I live in Montgomeryville / Lansdale area, close to Doylestown, suburbs outside Philadelphia. Hopefully she can keep some projects going, thanks
Front Bumper with absorbers, reinforcement & SHO plate - has some road rash and puncture that can be covered by plate - $100
Rear bumper cover with absorbers and reinforcement - $100
Header panels - both aftermarket, $20 each
1st - fit well but has lower mount hole missing for driver side marker
2nd - did not fit well and shop ended up cracking it in a few spots
Passenger side marker - original, $20
Driver taillight, original - $20
Passenger taillight, original - small crack & light scratches, $20
Rear License Plate Molding / Valance - $60
Rear spoiler with 3rd brake light - $100
Left rocker molding & ¼ panel lower claddings- $60
Right rocker molding & ¼ panel lower claddings - $60
Stainless steel rocker molding bracket - you may need to cut other holes to mount it, - $60
Door trim panels - $20 each
Front and rear leather seat cushion set - $60
No front seat frames/tracks. Front seats worn, trim broken, stitching on top of rear seatback is coming apart, bottom in good shape
Catback exhaust that I pieced together with AM parts, not stainless - $400
Includes flex pipe, intermediate pipe, rear Y pipe, Dynomax Super Turbo Mufflers w/ original tips - custom mounted passenger side so you may need to customize or get bracket welded for correct mount
Original rear Y pipe - $60
Set of 4 16” Slicer wheels, tires (7/32 fronts, 4/32 rears) caps & factory wheel locks - $200
Console - $130 shipped
Driver fender & liner with cladding & 24V emblem - $60
Passenger fender & liner with cladding and 24V emblem - $60
New set of NGK platinum plugs, Airtex wire set & ignition coil pack with cover - $60
Reman Alternator – no miles, $100
Alternator (core) - $20
New Starter - just installed, $60
Battery tray - treated rust and painted with black Rust Reformer, $20
Mass air flow sensor - $20
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
New Timing belt idler pulley - $60
Plunger type timing belt tensioner -leaking, $40
Pulley type timing belt tensioner - $40
Timing belt tool kit - $30
Serpentine Upper Idler pulley with new bearing installed, also fits tensioner - $60
Serpentine Lower Idler pulley - $40
Serpentine belt tensioner w/ pulley - $40
Serpentine belt tensioner, no pulley (spring rusty) - installed and it was notchy so took back off - $20
Harmonic Balancer - $40
Pioneer Bluetooth media player with 6.5’s, 6 x 9's and mounts - $80
Rear audio electronics - I have no way to test if they're good
Rear amp set - $40
Rear subwoofer - $60
Dash cover / cluster surround panel - $60
Glove Box - $20
Front door switches (driver new, pass used) - $20
Emergency brake pedal assembly - $20
Wiper switch - $20
Automatic climate control module - $100
Valve cover gasket set, installed briefly but was brand new - $40
New aftermarket IAC valve , I'll throw in old Ford unit. Replaced as I had IAC code - $40
Steering column metal cover - $20
Sold
Instrument cluster
Original CD player
FM Radio with tape deck
O2 sensors
DIS
OG-SHOguy
Same as JBeck
Houston, TX
"43. Instrument cluster with white face gauges -$40" Let me know where to send payment!
47. Console - $60, Would you ship this? If so I will take this as well.
Irish Pride
Irish Inside
MusicCityUSA
Can you tell me what condition the drivers floor mat is in? I can see part of it in one pic but not the whole thing.
Edward Birdsall
Brewster, NY
Looking for the following parts for my 94 sho. Sunroof Switch: OEM Part # E6DZ15A656a and Odometer Reset Button, the push extension that screws into Instrument Cluster. Also looking for a pair of new front headlight housings.
1MadSHO95
Stunt Driver
Middletown, Ohio
I’m interested in the front bumper cover, side marker lights, and passenger side fender.
Could I get a price with shipping to 45042?
Thanks!
johndallara
Chapel Hill, NC
Driver AM side marker - $20
Driver headlight - original, $20
Passenger headlight - original, $20
Near complete interior wiring harness (cut at fuel pump, doors, and a few places under dash but relatively complete - $200
Front and rear leather seat set - $100
Front seats worn, trim broken, pass motor doesn't work
Stitching on top of rear seatback is coming apart, bottom in good shape
Catalytic Converter with rear ****** repair (was sealing fine) - $100
Spare with jack - $40
Console - $60
Newer Exide Nascar Extreme 34X 800 CCA Battery - $40
Cold air intake - $80
Starter (core) - $20
Throttle Body - $20
Air box with good filter - $20
Fog lights with brackets - $60
PS pulley - $20
Water pump pulley - $20
Cam pulleys - $40
Plunger type timing belt tensioner -leaking, $80
Serpentine belt tensioner (spring rusty) - installed and it was notchy so took back off - $20
Rear amp set - $40
Seatbelt set - $100
Glove Box - $20
Wiper switch - $20
Misc interior trim, package shelf, trunk liner, etc – lmk what you need
Valve cover set with new gaskets installed - $40
Ingalls Rear control / trailing arms - $100
Sold
Instrument cluster
Original CD player
O2 sensors
DIS
interested in front bumper cover and assembly parts
JD
OG-SHOguy
Same as JBeck
Houston, TX
DIS
Are the rear control arms the adjustable ones? If they are, I will take them...let me know where to send the payment via paypal
Greg Corcoran
Denver metro area
I hope you still have the parts and can ship to 80503. I desperately need the rear bumper! I was rear ended on my way to work by an uninsured, recently bankrupt, meth head driver and my insurance wants to total my SHO because the adjuster put the rear bumper as an allowance
like it's made of unobtainium (almost 2 grand!!!)
because he cannot find one "on the wire" in CO or WY. The rest of the repairs totaled only $1,877, but at $3,877 it's greater than 75% of the car's value and a total loss...
SHO4ROBB
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
Rear amp set - $40
Glove Box - $20
Wiper switch - $20
Sold
Instrument cluster
Original CD player
O2 sensors
DIS
I am interested in both the fenders (w lining and cladding and 24VDOHC emblem); Bad part is I am on west coast in Ca. Please contact me at [email protected]
hosbaldosho
