Form1le
Open to offers on everything, so please PM me with needs. Thanks
Parting out 1994 Taurus SHO ATX Auto 3.2L. Car & engine had 230K+ miles so please take that into consideration as I’m selling all parts AS IS with no returns. New parts listed below have virtually no miles as I only drove the car a few hundred miles. Car was scrapped. Exterior Opal Frost, Interior gray leather. I’ll try to include mounting hardware where I can. I listed the big stuff, but if you don’t see something let me know. Prices do not include shipping. I can’t ship the big stuff, sorry. I’ll start a separate section below for what sells. I live in Montgomeryville / Lansdale area, close to Doylestown, suburbs outside Philadelphia. Hopefully she can keep some projects going, thanks
Front Bumper with absorbers, reinforcement & SHO plate - has some road rash and puncture that can be covered by plate - $100
Rear bumper cover with absorbers and reinforcement - $100
Header panels - both aftermarket, $20 each
1st - fit well but has lower mount hole missing for driver side marker
2nd - did not fit well and shop ended up cracking it in a few spots
Passenger side marker - original, $20
Driver taillight, original - $20
Passenger taillight, original - small crack & light scratches, $20
Rear License Plate Molding / Valance - $60
Rear spoiler with 3rd brake light - $100
Left rocker molding & ¼ panel lower claddings- $60
Right rocker molding & ¼ panel lower claddings - $60
Stainless steel rocker molding bracket - you may need to cut other holes to mount it, - $60
Door trim panels - $20 each
Front and rear leather seat cushion set - $60
No front seat frames/tracks. Front seats worn, trim broken, stitching on top of rear seatback is coming apart, bottom in good shape
Catback exhaust that I pieced together with AM parts, not stainless - $400
Includes flex pipe, intermediate pipe, rear Y pipe, Dynomax Super Turbo Mufflers w/ original tips - custom mounted passenger side so you may need to customize or get bracket welded for correct mount
Original rear Y pipe - $60
Set of 4 16” Slicer wheels, tires (7/32 fronts, 4/32 rears) caps & factory wheel locks - $200
Console - $130 shipped
Driver fender & liner with cladding & 24V emblem - $60
Passenger fender & liner with cladding and 24V emblem - $60
New set of NGK platinum plugs, Airtex wire set & ignition coil pack with cover - $60
Reman Alternator – no miles, $100
Alternator (core) - $20
New Starter - just installed, $60
Battery tray - treated rust and painted with black Rust Reformer, $20
Mass air flow sensor - $20
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
New Timing belt idler pulley - $60
Plunger type timing belt tensioner -leaking, $40
Pulley type timing belt tensioner - $40
Timing belt tool kit - $30
Serpentine Upper Idler pulley with new bearing installed, also fits tensioner - $60
Serpentine Lower Idler pulley - $40
Serpentine belt tensioner w/ pulley - $40
Serpentine belt tensioner, no pulley (spring rusty) - installed and it was notchy so took back off - $20
Harmonic Balancer - $40
Pioneer Bluetooth media player with 6.5’s, 6 x 9's and mounts - $80
Rear audio electronics - I have no way to test if they're good
Rear amp set - $40
Rear subwoofer - $60
Dash cover / cluster surround panel - $60
Glove Box - $20
Front door switches (driver new, pass used) - $20
Emergency brake pedal assembly - $20
Wiper switch - $20
Automatic climate control module - $100
Valve cover gasket set, installed briefly but was brand new - $40
New aftermarket IAC valve , I'll throw in old Ford unit. Replaced as I had IAC code - $40
Steering column metal cover - $20
Sold
Instrument cluster
Original CD player
FM Radio with tape deck
O2 sensors
DIS
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
Rear amp set - $40
Glove Box - $20
Wiper switch - $20
Sold
Instrument cluster
Original CD player
O2 sensors
DIS
