Dyno records
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Work in progress
89-95 V6 - NA
284/246 - zach44102 -
95 MTX 3.3,SS SII cams, 12.5:1 forged pistons, ported intake, butterfly delete, udp, E85
281/255 - Irish Pride - 95 MTX 3.4 Stroker, 10.25:1 Wiseco, ported heads, Tri-flows, 32lb Accel injectors, ported intake, 69TB, 75mm MAF, Borla, every bolt on possible, on 93 pump gas. 09/02/21
258/206 - Toolman - 89, 3.0, head/cams, 80MAF, custom catless Y and 2.5" exhaust, EH/BBB, pistons?, LPM
257/214 - AREA 91 - 91+ 3.2, +40cams/adj sprockets, UDPs, EH/BBB, 69TB, 80MAF, headers, cat back, Tweecer
256/221 - Ishodu - 95 MTX, 3.2, hi-comp pistons, custom cams, and more
255/217 - FREAK SHO - 95 MTX 3.2 with lots of mods
252/200 - Lance Cheney - 92 3.2, BBB/EH, SHOshop Y, 3" custom catback, S2 cams, 80mm MAF, cam sprockets
246/214 - jayro - 94 3.2 MTX. TriFlow's, ported/BBB, 69TB, 73MAF, ShoSource catlessY, catback, UDP
237/206 - RJ-92 - 92 3.2, Ported intake, S2 cams, SHOshop Y, Dynomax catback, UDP, Pro-M 77
228/220 - Irish Pride - 89, 3.3 Hi-comp pistons(10.6:1), Tri-flows, EH Runners, BBBs, gasket matched stock heads, 9lbs Flywheel, cat-less equal length Y pipe, Borla exhaust, unknown SCT tune, slipping clutch... Updated numbers coming
225/209 - kevinspann - 92, 3.2, UDP, SHOshop stage 2 cams, PP y-pipe with gutted cats. 17lb flywheel, quaife
217/200 - ACV1081 - 91 3.2, BBB/EH, phenolic spacers, UDP, 69mm TB, Pro-M 75, catted Y, Borla catback
214/183 - yamahaSHO - 95, BBB/EH, S1 cams, catted Y, 3" catback, UDP, 9lb flywheel, Tweecer RT
214/196 - jedhed - 80mm MAF, CAI, BBB/EH, UDP, SHOshop catted Y
210/210 - AREA 91 - 91, 3.2 with 3.0 cams, SHO SHOP UDPs, PP/cat-less Y, Dynomax Cat Back, TwEECer
207/194 - SHODOGG - 92 - BBB/EH, PRO-M 8, UDP, SHOshop catted Y, Custom catback with Magnaflow mufflers
204/192 - firstgen89sho - 90, SHOsource catted Y, K+N panel filter
201/182 - NotSoSlowSHO - BBB/ported intake, 80mm MAF, custom Y, 3" single exhaust, Tweecer
197/188 - Geek SHO - 89?, SHOshop catted Y, mufflers, K+N panel filter
197/185 - ghostrider - 91
194/199 - Huntervf - 89, 80mm MAF, UDP, PP catted Y, Dynomax mufflers, LPM
193/193 - Gez89SHO - 89, stock
193/175 - SHOkid13 - 93 MTX? - unknown mods
191/182 - SASHO91 - 91, stock
188/180 - yamahaSHO - 92 hacked up SHO Shop Y-pipe
188/177 - Bob90lx - 90 sho-powered probe - 250k mile stock engine
186/185 - Imaperson - 89, stock
186/182 - 19sho90 - 90, ported/BBB's, catless Y
185/173 - blue92 - 92, stock?
183/186 - SHODOGG - 94 ATX, PRO-M 80, Ted B LPM, PP catted Y
179/175 - SHOkid13 - 93 MTX? - stock
175/191 - _JR_ - 95 ATX, BBB's
kevinspann
Don't take my advice.
Richmond VA
225/209 92, lower mileage 3.2, SHOsource UDP, SHOshop stage 2 cams, PP y-pipe with gutted cats. Stock intake and catback. 17lb flywheel, quaife, Cobra brakes, 17s.
AREA 91
PA SHO SHOP
Area 91
Daily Driver:
1991 Mocha Frost
stock 3.2 bottom end
stock 3.0 cams
SHO SHOP under drive pulleys
Performance Plus stainless Y pipe without cats
Dynomax Cat Back Exhaust
TwEECer
210/210
1991 Green Plus:
SHO NUT + 40 cams
SHO NUT adjustable intake and exhaust sprockets
extrude honed runners
big bore butterfly's
hand ported heads and intake
69mm throttle body
SHO SHOP 80mm MAF
SHO BROS ceramic coated headers
electric exhaust cutout
SHO SOURCE cat back
TwEECer
257/214
:dribble:
336/318 with a 100 shot of N2O!
jayro
Auburn, In
'94 3.2 MTX. TriFlow Cams, ported/gasket matched intake, BBB, 73mm MAF, bored TB (69mm?), catless ShoSource y-pipe, Aftermarket catback (DynoMax or MagnaFlow...cant remember), UDP
246whp/214wtq
Off Road SHO
Moderator
95 3.2, stock without the butterflys now, 42lb Cobra Injectors, blah blah turbo, high flow fuel pump...30 shot of nitrous in case the LS-7 powered buggy in the next lane is also turbo'd.
300 WHP/ 298 WTQ
2,000lb rail
Too scared to drive it now. Tried to order bigger cajones from Summit, they said I'm out of luck...
Tom
dohcsable
Gold Calipers>*
Indiana
300 WHP/ 298 WTQ
2,000lb rail
Tom
I'm scared to launch the Raptor off two step......5psi on takeoff sounds like an awful idea. I too need to find bigger cajones.
zach44102
BIG TURBO
Georgia
3.3 SHOSHOP stage II cams, wiseco 12.5:1 forged pistons, ported intake, butterfly delete, udp, stock tune
yamahaSHO
E85 whore
Arkansas
zach44102 has new numbers.
lingyuair
