LT
All, H20 pump in, thermostat in, timing belt on new hoses, sweet! Started right up and running way cool! Had to burp the system a couple of times for temp to stabilize.....then !#%* car began to act up again. After starting and running fine 6+ times, now intermittently decides to take multiple start attempts before starting. When it does start the tach does not work until speed is up then all is fine. Prior to performing work I disconnected only the battery...I gapped the crank position sensor per procedure with a garden variety feeler gauge. Have yet to run codes. Have day off tomorrow would like to finish the job.
