subframe connectors in a wagon???
Mike Spataro
E.Meadow, NY
Hi Bill,
Please share any information on the sub frame connectors on a Taurus wagon. I believe the area in the rear wheel is different than the sedan. The Gen I wagon and Gen II wagon are the same frame FYI. Do you know of anyone who has installed them?
Thanks, Mike
1slickRED89
Guest
Toledo Ohio
the guy who goes by NOOK made some and sold them on ebay. he said that he can cut them down to make the sedan version so they must be longer or somethingbu tthe same overall design. sorry no contact info. lateron, Corey
3.8Lwagon
Shaggen Wagon
the saden will not work on the wagon. the rear wounts for the strut control arm is different.
i have a set from prosuspension but i have yet to have them installed. i am waiting to have it done at the same time as my exhaust.
did you do a sho conversion to your wagon? i noticed your sig. also did you use the dynomax cat back exhaust? or is it a custom setup?
SHO92
Upper Freehold, NJ
I was under the impression that "Thumper" had SFCs, but if everyone seems to think that they don't fit, I'm probably wrong. Its been a while since I've seen the car.
Mike Spataro
E.Meadow, NY
3.8LWagon,
I installed the mufflers and the Y pipe section in the rear only. The pipe welded right up to the existing stock 93 ATX exhaust. The loop portion of the stock set-up fits right in with a minimum adjustment of the hanger to the rubber isolator. The mufflers bolted up without a problem but on the passenger side you will need a bracket that is mounted off the rear bumper mount to connect a rubber isolator to hold the passenger side muffler. Make sure that you are happy with the way the mufflers are positioned before you weld the pipe.
Good luck, Mike
3.8Lwagon
Shaggen Wagon
the sfc connecters i ahve are different from the saden, (angles are different)
so the dynomax cat back fit with no problems other then the hanger?
