Stupid Squeaking Pullies!!
skippie
Monroe , MI
They drive me nuts! I have one on my SHO thats squeaking, as well as a few other cars in the family. Is there anything you guys rewcommend using to help avoid this? A special lubricant or something? When I splash water on the pullies the squeaking stops for a minute or two, but then starts back up again. Any info? Thanks.
Cobraii976
I am an idiot
yeah run out replace them with the impossible to find new pullies. Good Luck on the endevor.
Off Road SHO
Moderator
If water stops the squeaking, then it's not the pullies, it's the belts. It's just glazing of the belts. Go get a can of belt dressing from a reputable Auto parts house. Spray it where the belt meets the pulley and you won't have any more squeaking.
Tom
Rob94
Northbridge MA
Bad pulleys make a whining sound. And they are not impossible to find. FordPartsNetwork has them. I just ordered and replaced both of mine last year. Expensive, yes. Extinct, no.
MelectroK
Michigan
or see if you can press out and replace the bearring. Not sure what there like though.
JTSHO
NO SHO
winston-salem,nc
candle wax huh? my cars have the same issue. ive tried everything on my sho and my gl...the belt gets about a year old and squeaks constantly on both. any other suggestions? has anyone noticed belt dressing making it worse?
bgjohnson
iowa
the only reason belt dressing would make it worse is if the pulley was slipping slightly in the first place and the dressing worsened the slipping. and here's a trick that i don't condone but does work. take the pulley out, use a needle grease injector and try to get it between the seal where the bearings are at. usually it works.
Fourcats
Longview, WA
Yes, candle wax. If it works what do you do then....SMILE. If bearings are going out check the tensioners and/or belt tension to be correct.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
You do not understand what belt dressing does. It is not going to make it slip more. It does the exact opposite.
BTW, another "old school" method to stop squeeky belts is to use rubber contact cement instead of belt dressing.
JTSHO
NO SHO
winston-salem,nc
i tried wheel bearing grease just to try different things. it worked for a little while but not long. both my taurus's do it so im suspecting cheap belts maybe...i think i might try the candle wax btw, wouldnt rubber contact cement make the belt deteriorate due to the chemicals?
Cobraii976
I am an idiot
The bearing is Ford and we can't buy it unless we find a contact in Japan to smuggle us some NSK Ford Proprietry bearings. I've pressed 2 out and ran them through every bearing house in Detroit and can't come close with anything on the shelf.... But I'm getting closer.
Cobraii976
I am an idiot
where ya at in Michigan I'll hand you the exact bearing. Gimme a call 810-618-6135
