af_maineiac
Earlier this year, I purchased the Thunderstorm High-Low Down Pipe (w/hi-flow cats) for my '14 SHO. They were installed by a local Ford dealership, and everything seemed to go well with the install. But since then, I've noticed a loud resonating/drone exhaust sound upon acceleration -- but it only occurs in the 3,500-4,000 rpm range. (Best way to describe it is to think of a 4-cylinder import with an obnoxious muffler.) Aside from that, everything sounds fine at idle, low rpm's, and at WOT.
Is this normal, or is this something that I should take back to the Ford dealership to address? (I wasn't sure if anyone else had a similar issue with the down pipes.) The SHO seems to be running perfectly fine otherwise; no DTC codes were found when I checked the MyCalibrator tuner as well. Thanks in advance....
