93_SHO_FL
Ok, so one of my final issues with my 93 ATX is the AC. I have fixed just about everthing else now.
I took it to a local AC shop since it was blowing hot. I don't know much about AC systems.
They said it would need a new compressor, evaporator, hoses, and possibly accumulator, plus labor and recharge. They said this would be close to $1000+
I didn't want to spend that, so I decided to look at it myself.
I replaced the cycle switch, and noticed it was already converted to R134a system. So that saved me $50
I got a couple cans of the R134a w/ leak sealer. Charged it up til the clutch cycled. Then continued to charge it until it was at about 40-45psi while engaged.
It blows ice cold. Let it run for 15-20 min, then it disengaged and the heat turned on. Uh....WTF?
I turned car off, and back on, and ac worked again. I tried with the EATC as Automatic mode, and as MAX AC mode. Both had same result after about 20-25 min.
As soon as I shut car off, and turn back on, it's working again.
Could this be ambient temp sensor? Or maybe my EATC acting up? Bad relay somewhere?
I checked refrig pressure, and it didn't leak out. It blows ice cold for those 20 or so minutes...even when sitting at stand still.
Any suggestions are welcome. Thank you in advance!
