chrism3784
Drove fine one day, next day trying to start to go to work, cranks, doesn't fire. Ok, so I take my meto to work. When I come back, I tried hours to figure it out, and I'm usually good.
First, so I put to run the cooling fan kicks on, never usually does that. Stays on till key is turned back. I unplug the fan to not **** battery. The fuel pump also kicks on and stays running nonstop while key in run. Usually shuts off after a few seconds. Did some volt checks. Grounds to ICM ok, yel power ok. Red power out to pcm ok. All sensors getting 12v at there power wire. Changed out the ICM with one I knew worked before, same issues. Must be something shorted or something. I havn't checked for spark yet, daylight ran out.
Also I plugged the code reader up, does nothing, pcm doesn't even recognize it nor does anything when i click to test.
I'm at a total lost, any idea?
