SHOMeSomeBoost
Is stock boost 12 psi? I just received my SCT tuner to do my tune and it says that I'm currently maxing out at 8 psi. I haven't loaded the tune yet.
8-9 psi sounds right.
I have stock datalogs showing mine hitting 12psi during a shift at peak.... I will post them in a bit... But like what was posted earlier...these cars don't target boost for power... It's the other way around... You target a particular load and the car does what it needs to get there...it's a pretty neat way to do things...so boost will vary depending on driving conditions...Ok, thank you. Top Speed published an article saying stock boost was 12 psi. Dirty buggers. Also, SHOdded, I need to buy you a beer sometime. You are all things SHO.
I.E. when it's cold out and the air is denser you may use less boost. In the summer when the air is hot and less dense you may require more boost to produce the power you need... At least that's how it works out in my mind..
Sent from my Nexus 6P using Tapatalk
