Still won't start!!
3Xtream
NH
93 ATX 3.2L
Well guys here is the scoop Car died in shopping center parking lot All I get when I turn the key is one click. So I change the starter here is the strange part the car starts right after I changed the Starter and then I try it again and all I get is one click. I have cleaned all the connections and even changed the battery. Not sure where to turn to next. Oh some times if I try to start her a couple of times the silenoid will stop the one click and I here a little click coming from the drivers side fender wall not sure if it is a relay or something. Any ideas would be great. Thank you.
3Xtream
NH
It is a Gen2 the sileniod is attached to the starter I am not sure what the module is that is clicking on the fender but it might be a relay or something not sure if that would cause car not to start
BlackOnBlackATX
Dutchess County, NY
3Xtream, i had a similiar problem a month ago. car was fine. turn it off, go to start, click click but no start. turns out my battery cables were shot, so it wasnt getting any current to the motor. maybe its your problem. you should grab a voltmeter and find out. as for the clicking on the fender i really dont know. sorry man. you could always try "jumping" the starter and see if it works. if it does then its your cables. good luck.
