whiteman_01
Well-Known Member
Ok, For the last few weeks my car has been acting weird. Sometimes right around 5500-6000 rpm's it will start to break up. I have replaced the following with known good or new parts.
Fuel pump: new
Fuel filter: new
02's: new
55mm maf: known good
TPS: known good
Plugs and wires are within 5000 miles. When i would run codes i would come up with a 519 and a 556. The 556 is for the fuel pump circuit failure. A friend of mine found a schematic on how to test the IRCM and the high speed fuel pump relay tested bad.
So i picked up a good (tested) IRCM and put it in, and i am still having the same problem. The IRCM i took out was a "J" and the one i put in is an "M".
I realized that this started happening right after i changed the t-stat. When i put it back together i put one of the wiring bundles under the t-stat housing. These wires include the MAF, the TPS, and something else i think. I relized that it was tight against the bottom of the housing when i was putting it back together, but i didn't think anything of it.
One more thing, last night when i put the new IRCM in, my brother heard what sounded to be a small vac or intake leak but we could not pin point it.
Sorry for the long read, but thanks in advance for any ideas.
Fuel pump: new
Fuel filter: new
02's: new
TPS: known good
