still hard starting
patrick hubbard
Pratt, ks
after replacing the fuel pressure regulator and cam sencer my car is hard to start and smells like gas out the exhaust. and when it gets warmed up it will stall when I stop.
E1
Crash Tested
Chicago area
Excessive fuel or unburned fuel causing smell. Obviously.
Have you tried unplugging the MAF to see if it runs any differently?
stephen newberg
Ladysmith, BC, Canada
IAC sensor, is, I think the initials. Sometimes you can get away with cleaning it, but its fragile, and often you should just replace it. IIRC it is not an expensive part.
smn
gamefanatic
Barstow, CA
Article No.
97-9-5
04/28/97
LONG CRANK - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL - AFTER STARTING WHEN ENGINE ALLOWED TO SOAK FROM 1-4 HOURS - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 1/11/94 THROUGH 3/30/96
FORD:
1995-96 CONTOUR, CROWN VICTORIA, ******, TAURUS, THUNDERBIRD
1996 MUSTANG
LINCOLN-MERCURY:
1995-96 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, MYSTIQUE, SABLE, TOWN CAR, TRACER
LIGHT TRUCK:
1995-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES, RANGER, WINDSTAR
1996 EXPLORER
This TSB article is being republished in its entirety to include the 1995 4.6L Thunderbird/Cougar.
ISSUE:
After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking.
ACTION:
Replace the AC Valve with a revised AC Valve if no Diagnostic Trouble Codes (DTCs) are present. Refer to the following Service Procedure for details.
99sho-time
the car will dump a bunch of fuel if the IAC sticks? check fuel pressure first?
