still burning oil!
Sexymeatball
MA
Alright here's my problem. I had some crazy oil burning problems when i first got my car. It was so bad that it failed emmisions. Well, after the 60k tuneup, it was still burning oil so i decided to replace the remaining seals. Basically what i'm getting at is that i have replaced every oil seal in the engine, including the valve stem seals (those are a bitch to do). But my car is still burning about 1 quart every 500 miles. It passed emmisions with flying colors but it still burns oil. My question is will auto-rx help this? Because with all new seals, the seal restoring agent really wont be doing a whole lot. Or should i try and get to the bottom of this and ask where my oil is going? Cause there are no leaks and i have fresh seals absolutely everywhere. Your help is much appreciated.
MilTownSHO
Horicon, WI
Sexymeatball:
That's what you need to do! Forget AutoRX, figure out what the problem is first! thumb
shojuan
sunny San Juan Bautista,
GonadsAndStrife:
Sounds like your valve guides are worn or your piston rings are worn. A compression test will tell you whether its the former or the latter.
Or piston rings are stuck. If the rings are stuck the auto-rx will help. It can't fix worn valve guides or worn rings obviously.
Sexymeatball
MA
Oh yeah i forgot to mention (sorry). I have great compression. Did a leak down test while replacing the valve seals (woulda been stupid not to) and all 6 cylinder are in the excellent range. So this leaves the valve guides then huh? :( I would rather just keep buying oil than fix that. But what i dont understand is that if its burning so much oil, how did i do so well passing emmissions?
