starting woes
I'll_SHO_U
colorado
Awhile back I inquired about some solutions to my starting problem. After I took the connections to the solenoid apart and cleaned them and also the battery connections it still was makeing the clicking sounds. I also checked the wireing and everything except for a split in the wire was ok. I took the battery out and had my friend charge it and he said it didn't need it. I put everything back together and it started but just once. After I shut it off and tryed to start it again, the clicking noise came back. My friend was standing in front of the car he noticed that the solenoid wasn't clicking, it was a relay on the firewall. Almost in the middle of the intake on the firewall is a connector for the ABS test(red cap), another connector and then a relay to the right of that. What does this relay do? What does the connector to the left of the relay do? When I went out to start my car today, nothing happened, no clicking no nothing. After taping on the relay and checking connections the car tried to start but acted like there was a huge draw on the battery and would barely crank over. After that nothing. Any ideas? Also, should the solenoid be able to move around in the case that surrounds it? Thanks for the help.
rangerj
Brunswick, Ohio
I'll SHO U,
Have you tried an amp draw test on the starter? It sounds like the starter is gummed up and does not want to crank. You could remove the starter and have it tested at an auto parts store if you do not have access to the equipment. rangerj
