Ever since I jumped my dad's 2000 Carrera 4 my SHO has had a hard time turning over. It has been getting progressively worse since then (was in December). As of today it almost won't even turn over at all.
I'm thinking my battery may be not putting out the amps it should. The battery is about 8 months old, but it is possible that the Porsche drained a TON of amps. My battery has been relocated to the trunk, but I don't see how this could effect starting, as it started fine before the jumping occured.
On the other hand I have replaced 4 starters in the car, and the last one went out like this. The last one though died within about a week of it having trouble turning over.
Once running the car is fine, runs just like it should with no quirks electrically. The battery reads 12.6 volts when parked and the engine not running.
A few possibilities I'm thinking of trying before replacing my starter are:
1) Have the battery checked out to make sure it puts out the proper amps
2) Check the connections at the starter
3) Check my starter grounds
4) Try another battery or use someone's car to "jump" mine
Anyone have any ideas before I pony up for another starter?
