Starter Wires
SHOdude03
Wisconsin
Hey, finally managed to start putting my SHO back together after about 6 months and I can't seem to remember which wires go where. If someone could tell me which wires go where on the starter for a 90 SHO, I would greatly appreciate it, thanks.
TYSHO
Earth
Your + wire from the battery goes to the starter solenoid, on the firewall, on the post closest to the front bumper. Then, the back post has a + wire that goes to the starter and is bolted on the back, passenger side. The ground cable from the battery is directly connected to the front of the starter, where it bolts up to the tranny. It's the one that you slide on the bolt and is held down by a nut. There's also a bracket there to hold the + wire from the start solenoid to the starter.
