ok, fear not 92SHO, we'll see what we can do. the DIS module is on your crossover tube on the intake of the engine. if your looking right at the engine, look to the left, youll see a tube that joins the back and front of the intake. on the side of this tube there is a gray rectangle with two wiring harnesses on it. thats your DIS. the screws that hold it on the intake AND the bolts that hold that tube in place (two of em on either end on the opposite side of the DIS) all serve as electrical grounds. now being metal they will corrode and weaken the ground ability. sometimes the bolts need to be taken out and all the metal mating surfaces touched up with a wire brush. there is also a strap on the back of the intake toward the firewall (same side as the DIS module) this is bolted onto the car, this is also a ground.
the PIP sensor is part of the crankshaft position sensor (CPS). i found this out the hard way when my DIS was not properly grounded and i started getting this code along with crappy acceleration.
now i *believe* but for some reason am not totally sure right now that the CID (cylinder identification sensor) is your camshaft position sensor. i could be wrong on this, but im fairly sure but for some reason am having mental blanks.
hope this helps.
