Anyone who wants to build a stand alone fuel system that plugs into the stock Fuel injection lines for the SHO heres the leg work. THIS IS FOR USING THE STOCK REGULATOR AND 155 LPH AND LOWER RATED PUMP.
uses an-6 lines and fittinings
1- fuel cell of you choice, most have 3 AN-8 fittings , supply, return , vent. ( reqiuires AN-8 to AN-6 adapters, see below)
1- Fuel pump, walbro external pump, 130 or 155/160 LPH
( see other thread of fuel pump http://www.shoforum.com/showthread.php?t=92466)
2- AN-6 to 10mm x 1. adapter ( for fuel pump)
4 - 90 deg fittings
4 - straight fittings
2 - AN-8 to AN-6 adapter to attach 90 deg to fuel cell
1 - AN-6 inline filter of you chioce
1 - AN-8 roll over valve for fuel cell ( not shown)
1 - AN-6 to FORD quick disconnect, supply
1 - AN-6 to FORD quick disconnect, return
Enough AN-6 line to finish the job
Side note, I have a fuel pressure gauge and adapter block on the way , it fits right before the AN-6 to Ford supply adapter fitting
4 - 90 deg fittings
