stalls at idle, backfires
MrRed
green 93 sho
MI
i did the search and really didn't come up with what I have. at idle it jumps around very rough in the rpm's. i'd say from 400-1500. when you hold it above 1500 or 2000 it smooths out. below that it also backfires with light throttle input. I just threw new plugs in it. it has newer wires that look to be in good shape, as well as what looks to be a replaced ignition module. car has sat for at least 5 months plus. has a full tank of gas according to the gauge. and i also cleaned the MAF. starts up fine warm or cold. seems to act worse when it gets warm but haven't really gotten it up too temp.
MrRed
green 93 sho
MI
ok, replaced the IAC. it will actually idle now for awhile then it acts up. not as bad as before and the backfiring is pretty much gone. just won't idle now....
MrRed
green 93 sho
MI
hmm... no love for a newbie and fellow SHO owner....
AREA 91
PA SHO SHOP
Area 91
Double check the firing order.
Check for vaccum leaks on the intake.
MrRed
green 93 sho
MI
don't suspect firing order as it would ALWAYS idle rough. did a smoke test to check for vacuum leaks and it passed. took my ignition module to the parts store and they ran it on the machine 5 times and it passed....
if i unplug the MAF should it idle or not? because when I do that it seems to run fine but it just won't idle....
MrRed
green 93 sho
MI
oh, and the car don't have cats as of right now.
MrRed
green 93 sho
MI
lets go people, throw some ideas out here. my brakes will be fixed today and it will be plated.
MrRed
green 93 sho
MI
new update this morning. no start.... getting no spark since I had the ignition module tested....
MrRed
green 93 sho
MI
ok, so I unplugged the CCRM, pluged it back in, beat the crap outta it with my screwdriver handle. and I'm back to where I was. It will start. then die when the rpms get between 1000-1500
SuperHO
Mental Patient
St. Joe, MI
are all your grounds tight? Are the two 12mm bolts for the crossover tube tight? How about the ground strap on the back of the intake?
MrRed
green 93 sho
MI
grounds are intact and look ok. car does the same thing with the MAF hooked up as it does with it unhooked.
SuperHO
Mental Patient
St. Joe, MI
Okay...you say the car sat for 5 months. Was it ever started during those months? Have you tried changing the fuel filter? Does the gas smell like gas or paint thinner? Have you done anything at all to the car besides what you've already mentioned? Does the check engine light come on? Have you pulled codes?
MrRed
green 93 sho
MI
gas smells good. fuel filter looks newish like the plug wires. it has a new IAC. new plugs. firing order is correct. cleaned MAF, no vacuum leaks. hooked up a new ccrm with no changes. did a idle relearn with no luck. tried to pull codes but it gives me nothing... thats where I am. sometimes it will idle fine cold then backfire and stall before it gets warm, sometimes it will not idle cold and backfire then run fine warm. it's driving me nuts.:swing:
SuperHO
Mental Patient
St. Joe, MI
when you say pulling codes gives you nothing, do you mean it gives you the 111 system pass code or it gives you nothing at all?
MrRed
green 93 sho
MI
ok people, I got codes out of this thing. 211 and 542.
